lstinthot wrote:lutorm wrote:jerryhain wrote:My plan for the turbo at the moment is to add water cooling with a small radiator mounted lower than the turbo and the reservoir mounted well above the turbo for passive cooling. I really want to see how little cooling fluid I can get away with. If it works that will probably be my cabin heat source too.
I think you want the radiator above the turbo. The idea is that hot water from the turbo will rise into the radiator and cool down, setting up a thermal siphon. The Garrett white paper referenced earlier in the thread talks about how to facilitate this self-circulation.
This is correct. The hotter water is less dense than the colder water. As the water cools it becomes more dense (heavier) and therefor will want to go down. In a closed loop, its this heavier water that is driving the other leg back up into the radiator. The Radiator needs to be the high point in the system. We use this principle in the power plant for natural circulation. Our Steam Generators are higher than the reactor just in case the reactor coolant pumps fail we can generate enough natural flow to keep the reactor cool. Heat sink higher that source, minimize bends and use as large of tubing as possible to reduce friction.
Best of luck
n307tw wrote:...It is encouraging that Mark and the factory are looking at a cooling solution for the turbo as that is probably part of the problem, but I am speculating like the rest of us.
n307tw wrote:1. Is there any downside to having a completely separate oil system for just the turbo with a second oil cooler?
2. Has anyone looked at or experimented with the Royal Purple Fully Synthetic HPS formula in their Aerovee/Turbo?
Sonex1517 wrote:n307tw wrote:...It is encouraging that Mark and the factory are looking at a cooling solution for the turbo as that is probably part of the problem, but I am speculating like the rest of us.
As another disgruntled ex-turbo owner (mine is in a box in my garage now) I am going to comment on this. I am not at all confident Sonex is going to do anything at all to improve or resolves issues with the turbo. I am confident I am screwed out of several thousand dollars.
As soon as life and funds permit, I am putting a different engine up front - probably a Corvair 3.3L at this point.
Users browsing this forum: Google [Bot] and 2 guests
