daleandee wrote:SonexFactoryTech wrote:Sadly, this post seeks a reaction by omitting some (all) of the details.SonexN76ET wrote:Please watch your accusatory comments as you are not just hurting the manufacturer but all builders and owners. We are all in this together.I agree ...
Area 51% wrote:As far as my "accusatory comment" goes (and I guess it was deleted)
Area 51% wrote:While doing a dry-run assembly of the parts I actually have in my possession, I ran into an interesting interference. The top oil cooler adapter is not tall enough for the cooler to clear the bolt-boss holding the case halves together. Not wishing to bother Sonex with my petty problems, I'm planning on grinding away enough material on the case to allow the cooler to lie flat. Can someone measure the thickness of their cooler adapter and report back please. Mine would have to be about 1/16in thicker to allow clearance.
Anyone else run across this problem? Left unnoticed, it doesn't seem like it would take long to wear a hole through the cooler. At the very least, a leak at the seals seems probable.
Butt/Head-scratching never in short supply here @Area 51%
