I have to second everybody praising the Lonnie Prince’s props, I have a 54x48 P-Tip on my VW powered Sonex and absolutely love it.
At first I thought the great performance I was getting from my VW engine was mostly related to the fact that I have a slightly higher displacement engine than most (94mm bore x 86mm stroke = 2387cc), now I believe the prop probably plays a huge role as well.
At one stage, some people on this forum were actually questioning my numbers when I published them, so I made a video, here it is again for those who have not seen it:
https://www.youtube.com/watch?v=tqVj2IJEbHI&t=5sWatch the airspeed and altimeter closely, note that the numbers are in KT, not MPH.
I start off cruising 120KT at 1750ft, I then push the throttle wide open whilst maintaining 1800ft, the airspeed is approaching 150KT before I pull back the throttle, it was still going up but I got an EGT warning which you can see on my flashing on my E1 as well if you look closely.
You might wonder what climb performance with this prop since it cruises so well, so here’s my first flight video which demonstrates that too:
https://www.youtube.com/watch?v=VKGuEdH9Fcs&t=283sI don’t have a VSI but if you just watch the cockpit video between 3:47 where I start climbing from 30ft, and 4:15 where I reach 530ft, that’s just under 30 seconds to climb 500ft so I’m seeing 1000-1100FPM here.
Of course this is my first flight ever so weight was minimal at the time.
Anyway, in conclusion: Prince props, highly recommended!
