lpaaruule wrote:Anyway, if there are to ideas, and the copper RTV doesn't work, I think I'm going to have the slip fit welded.
Hi Paul,
I'm guessing you're referring to the Jabiru 3300 exhaust system. There was discussion about this on the Jabiru Yahoo Group. I believe you have to be a member to view the messages:
https://groups.yahoo.com/neo/groups/JabCamit/conversations/messagesI fly a Corvair and it doesn't have this concern as the head is one piece and the three into one exhaust system is also. I mention that because the baffles on the Jabiru are known to crack and I believe if you welded the exhaust the same thing would happen as the separate heads tend to heat differently and move separately. That movement would cause cracking, if not at the welded joint, somewhere else in the system.
As much of a pain as it might be, using something similar to the Rotax "cup & ball system " might work. We used to keep them lubed but they sealed pretty well against the movement.
Dunno if this helps at all ...
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
168.7 hours / Status - Flying
https://www.youtube.com/watch?v=1VP7UYEqQ-g
