RodgerC wrote:And yes, I remove my cowls after EVERY flight in prep for the next preflight.
mike.smith wrote:The point is simply that everything has a failure mode. Nothing is perfect. There are tradeoffs for everything. Just because something can fail does not automatically make it a liability. For anything mechanical, having a backup is the wisest choice of all.
lutorm wrote:If one wants a dual ignition, the Aerovee magnetrons seem quite good as the stupid-simple, self-contained, system.
lutorm wrote:It would be quite easy to replace the fixed-time secondary ignition with an aftermarket electronic ignition system. The only hardware needed would be to replace the trigger magnet with a toothed trigger wheel since you can keep the existing coils.
lutorm wrote:On the other hand, a Sonex isn't really a traveling machine, so I'm not sure it's worth the complexity.
rizzz wrote:I have a Bendix D2000 dual magneto directly driven from the crankshaft on the back of my VW:
Sonerai13 wrote:kmacht wrote:I would say that my experience contradicts that. When I lost the trigger magnet the engine would not start. The engine turned over good and fast, battery was fully charged but it would not fire. Maybe the earlier aerovees had a different starter?
Well Keith, your sample size is one. Yes, maybe your engine won't start on the magnetrons alone. But that does not mean that ALL AeroVee engines won't start on magnetrons alone. Yes, the early AeroVee engines did use a different starter, but I've started them with the current SkyTec starter on magnetrons alone, so it can be done.
Sonerai13 wrote:kmacht wrote:Well Keith, your sample size is one
GordonTurner wrote:An important consideration in comparing the aerovee and Corvair ignitions is that the six cylinder Corvair will run reasonably smoothly and produce good power on five cylinders. Typically four cylinder engines run extremely rough and as a result produce little useable power with one cylinder out.
daleandee wrote:Other have noted recently that the recommended spark plugs are being hit by the pistons and it was suggested to grind a relief in the piston tops. I can't help but marvel at such statements as that seems to me to miss the point and not direct the fix at the source of the problem.
