lstinthot wrote:If you are buying a kit, those parts are prebent. I am scratch building and those parts were not too bad to bend. I ended up making the Dave Clay brake. It does adequate. If I had the space, i would have a nice big 8' brake with its own space. Are you looking at buying a started "A" model kit and converting to the "B" Model and said kit does not have the spars?
Not looking to convert an A to B. Considering a new B kit. I’m new to the Sonex world....
I didn’t realize how responsive the factory was to questions.... super quick response... refreshing...
Official word from Sonex with regards the tail kit advises the HS forward spar “heavy aluminum” center spar bracket does come pre bent on the straight tail, the forward spar on the VS needs the lower “paddle bracket” bent.
With regards the V tail, none of the heavy aluminum spar brackets like the “hockey sticks”come pre bent.
Appreciate you guys replies - Thanks !
