3D printable stick grip
Postby kevinh » Wed Nov 29, 2017 6:22 pm
Hi ya'll,
I decided to print my (very simple) stick grips on a 3D printer. I used a woodfill composite filament and it feels nicely like wood. I'm not yet sure if I will stain them.
Here's the design file needed if you want to print your own. Parameters such as finger spacing is customizable:
https://www.thingiverse.com/thing:2678411
kevinh
Re: 3D printable stick grip
Postby Sonex1243 » Wed Nov 29, 2017 7:14 pm
Those look great! Thanks for sharing. Did you happen to experiment with wing tip light mounts? I have been looking around for a mount to fit my AEROLED Pulasr EXP lights since my gauge pod mount area is a touch too small for the light footprint.
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby kevinh » Wed Nov 29, 2017 10:51 pm
Sonex1243 wrote:Those look great! Thanks for sharing. Did you happen to experiment with wing tip light mounts? I have been looking around for a mount to fit my AEROLED Pulasr EXP lights since my gauge pod mount area is a touch too small for the light footprint.
Yep - I made a set of aeroled pulsar nxp mounts (would those fit for you)? They seem quite nice though I haven't yet mounted them to the wingtip. Thanks to Kerry at Sonex for the dihedral info - it seems like they should have a perfect arc and easy placement: https://www.thingiverse.com/thing:2508987
kevinh
Postby chris » Thu Nov 30, 2017 5:02 pm
Thanks Kevin
Chris
Sonex 1409
Slowly Scratch Building
Site Owner/Admin
chris
Site Admin
Postby Sonex1243 » Sun Jan 07, 2018 1:00 pm
What kind of 3D printer are you guys using? There is a lot out there ranging from super cheap to high dollar!
Ken S
Fuselage on gear
Jab 3300 received!
Sonex1243
Postby kevinh » Sun Mar 11, 2018 10:05 pm
I use a MakerFarm printer (because I had a gig working on the Marlin firmware most 3d printers use). However, there are two I'd recommend:
* Anything from Prusa. They are widely regarded as the best unless you want to spend >$1500. Approx $700, good build volume, just works, super good support. https://www.prusa3d.com/ (note - there are many clones, unless you want to futz with them a lot, just buy the real thing. You can buy it as a kit, it is easy to assemble). Can actually print replacement parts for all the plastic parts on the printer (the hw and sw are open source).
* The Monoprice printers are quite nice considering their low price - $160-$300.
kevinh
Postby ihab » Sun Mar 11, 2018 11:22 pm
+1 to the Prusa recommendation. You can save some money if you buy the kit and build it yourself, and in so doing learn how the thing goes together. If you can assemble a Sonex rudder you can put together one of these. I have a Prusa i3 Mk2S, and the newer i3 Mk3 is even better.
Ihab
Ihab Awad, San Jose, CA
ihab
Postby Brett » Mon Mar 12, 2018 12:44 am
I'm thinking when mine arrives I could print handles for my brake levers..once I get the hang if it maybe.
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby lutorm » Mon Mar 12, 2018 3:46 am
I have the TAZ6. It's expensive (although I had a price alert from Amazon for a year until it dropped $400 from the list price) but the ability to print things like nylon and polycarbonate has been essential for my Aerovee intake experiment.
lutorm
Postby chris » Mon Mar 12, 2018 5:10 am
lutorm wrote:I have the TAZ6.
I used the TAZ6 to print the one in the picture I posted.
It's $2500 on Amazon: http://amzn.to/2HrjUxQ
They also have the smaller mini for $1250 but I've never used one: http://amzn.to/2FAEGuH
Chris
Sonex 1409
Site Owner/Admin
chris
Site Admin
Users browsing this forum: Google [Bot] and 60 guests
