EdW wrote:Are they worth the extra $2700.00? I see a lot of 'precision' hammering going on with the home-built version. Is this instead of regular rivet upsetting, or is there another reason for the bolt/hammer procedure? What have others done? Pluses/negatives?
mike.smith wrote:EdW wrote:Are they worth the extra $2700.00? I see a lot of 'precision' hammering going on with the home-built version. Is this instead of regular rivet upsetting, or is there another reason for the bolt/hammer procedure? What have others done? Pluses/negatives?
I scratch built my plane, including the spars. It's not difficult, or even time consuming. Getting the right stacking order is actually the toughest thing. It took me 80.75 hours to assemble BOTH wing spars. No way in Hades would it have been worth the $2,700 for me. That would have covered 3/4 of the cost of all my avionics. But everyone has different needs.
The bolt and hammer is for at least two reasons: 1) it's cheap! and 2) Some of the rivets are located in difficult or impossible locations for traditional riveting tools (the spar flanges get in the way). With a bolt you can carve out a recess in the side of the bolt to clear the spar. 2 or 3 wacks gets you a good rivet set. I had to drill out very few.
http://www.mykitlog.com/users/category. ... egory=4821
Assembly started on 5/23/10.
I wouldn't say I'm cheap, but my picture IS listed beside 'frugal' in the dictionary. That doesn't mean I wouldn't go for it if it's worth the investment.
