Waiex 49 wrote:It was the exhaust valve rocker on cylinder #4.
Why did it break?
I don’t know for sure, but I believe that cheap VW aero engine kits are made up from cheap aftermarket parts that don’t hold up.
What I can tell you for sure is that it isn’t much fun when your engine stops running. Things get real serious in a hurry and the “advantages” of a “cheap” engine aren’t of much comfort.
lutorm wrote:It's not trivial to find turbos that are small enough for a 100hp application. The turbo appears to run 5psi boost (10" Hg) which is a pressure ratio of 1.3, and 100hp gives an airflow of 10lb/min. If you look at even the smallest aftermarket turbos from Borg-Warner (S1BG) and Garrett (GT2052), that's below the efficiency range of the compressors. The smallest S1BG compressor might be reasonable, but they don't have an efficiency graph for it in their catalog.
Users browsing this forum: Dave Wolfe and 1 guest
