by Mike53 » Sun Jan 20, 2013 7:22 pm
If it broke only part way in drill to proper hole size from the other side (if thats possible)till you reach the broken bit then use a punch to drive the bit out the way it went in or sometimes just getting it pushed out far enough you can grab it with vice grips and slowly twist it out.Best to use a punch if you have the proper size but another dull drill bit will probably do the trick.
Been there done that.
Mike
Mike
Antoine de Saint-Exupery
