A friend, Brian Rebbechi, is building a Xenos and he used the Cleaveland Tools DIENQ dimple die set that a few people have mentioned, and I think the results are exceptional.
The process he used was:
1. Re-bend the nose skins so that they are a better fit against the ribs. Quite a few builders perform this operation. Brian used the Tony Spicer bend brake method but you could also use the vacuum bag method.
2. Fit the skins and pilot all holes to #40
3. Dimple the holes using Dimple Die Set for 1/8" Adel N or Q - #40 Pilot (Item number DIENQ) available from Cleaveland Tools -
http://www.cleavelandtool.com/Dimple-Die-Set-for-1_8-Adel-N-or-Q-40-Pilot/productinfo/DIENQ/#.WjEJo1WWbIU4. Assemble the parts using 1/8" Clecos - the dimpling process enlarges the hole to nearly 1/8".
5. Drill or ream the holes to 1/8" (not #30) and rivet.
Only wish I had done the same.
