Onex107 wrote:I tried, unsuccessfully, to make a pair of pliers that could expand a standard pushrod tube after it was installed. There are pushrod tubes that are spring loaded also. Bill Larson used those. I'm not sure how well they worked. The threaded alum. tubes are infinitely adjustable.
SonexN76ET wrote:To stop the push rod tubes from leaking I use the EMPI white silicone pushrod seals. No leaks at all using these seals on the pushrod tubes. SILICONE PUSHROD TUBE SEALS, dune buggy vw baja bug https://www.amazon.com/gp/product/B0046VRW8C/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
mike.smith wrote:I've used 3 sets of those now, and they still leak. So the seals by themselves are not necessarily "the" solution.
MichaelFarley56 wrote:I think the most important part of preparing the pushrod tubes for installation is to make sure you stretch them a little so they seal well when you torque down the heads.
mike.smith wrote:MichaelFarley56 wrote:... as well as the 6 nuts holding the sump plate in place. I’ve tried different ways to seal those areas up but nothing has made much difference.
I'm pretty sure I have a slight weep from the prop hub, too.
vwglenn wrote:If you guys figure it out, let me know. Two decades of driving old VWs. Never ever ever ever had one that didn't leak.
Users browsing this forum: Google [Bot] and 60 guests
