A few photos may help.
This is page SNX-23 parts -06R and -06L as well as -05 made from stock.
These photos show the pitot tube clecoed to the mounting plate. In several of the photos I placed the bracket used to hold the pitot tube in place on the inside of the wing in the location the plans show it being mounted.
To hold the mounting bracket, three holes are pilot drilled and the plans show CCP-42 rivets. If I use the CCP rivets the head will make the pitot tube base sit up off the mounting plate.
So far, I think if I counter sink the mounting plate and use CCC-42 rivets to hold the mounting brackets it will work. This way the flush rivets, if done properly, should make this a non issue.
I am going to use CCC-46 rivets to mount the pitot tube to the mounting plate.
Robbie
