Sonex stick grip PTT
Postby petep » Wed Dec 13, 2017 3:11 pm
Anyone using the Sonex stick grip found a good push to talk switch to fit the grip?
petep
Re: Sonex stick grip PTT
Postby WaiexN143NM » Wed Dec 13, 2017 3:39 pm
Hi pete,
For our legacy waiex, we used the ray allen stick grips. The sonex molded stick grips a good ptt switch from B&c , newton KS. The larger one they sell. Your local electronics store may have some also.
Postby jeff0196 » Wed Dec 13, 2017 6:32 pm
Jeffrey W
Waiex 0196
AeroVee Turbo
jeff0196
Postby Onex107 » Thu Dec 14, 2017 2:13 pm
You guys that are looking for stick grips. Go to your nearest bicycle shop and check out the handle bar grips. The one I use is airfoil shaped and has finger notches. No problem drilling for a push to talk.
Postby Spaceman » Sun Sep 30, 2018 12:48 pm
What wire gauge do you guys use to connect the PTT switch? I'm not really getting into electrical stuff yet on my build, but I'm just about ready to install the control stick assembly, so I want to pre-wire it first so I don't have to take it out again later to run wires through it.
Also, I take it you solder the wires to the PTT button and just use a spade connector on the other end then?
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby mike.smith » Sun Sep 30, 2018 11:48 pm
Spaceman wrote:What wire gauge do you guys use to connect the PTT switch? I'm not really getting into electrical stuff yet on my build, but I'm just about ready to install the control stick assembly, so I want to pre-wire it first so I don't have to take it out again later to run wires through it.
22 ga. It's carrying next to no current; it just closes a loop.
