by sonex1374 » Fri Jan 15, 2021 11:18 am
I have one of those Amazon ultrasonic fluid level sensors that I've been playing with for the past few months. It works well within a narrow set of parameters, like setting up a test tank filled with water. However, I could not get it to reliably sense the fuel level in my Sonex tank. This could be due to the thicker wall of the tank, the plastic used in the tank, or nearby objects causing interference. It worked intermittently when testing on the ground, and not at all in-flight. Hopefully to Belite sensor is better matched to our uses.
Jeff
