by DCASonex » Fri Nov 03, 2017 9:37 am
My very early CAMit has the flywheel alternator, but followed development of the external alternators. There are two versions of the 40 amp mount. Original was mounted on top where we have the fuel filler box. The side mount, next to cylinder #5, version was developed with Sonex in mind, but it requires also modifying the fuel pump mounting. If you are using an AeroCarb and no fuel pump, this will not be necessary. I was about to opt for the new external 15 amp unit for less weight and to avoid compromised fuel pump mounting (Am using Bing.) Have some early CAMit drawings of the side mount 40 amp version, but no photos, PM if interested.
David A. CAMit 3300 #0004
