fastj22 wrote:I’ve helped install two echos and they just work. I’d go echo if I did it again.
I'm also considering the ECHO-UAT with SkyFYX-EXT for GPS. I'm currently negative transponder so I'll still need one of those and an encoder. Another option to the ECHO unit is made by Garmin and not available just yet. A bit more money but I'm certain that in 2025 Garmin will still be around for service if needed. Take a look at:
https://buy.garmin.com/en-US/US/p/540911Simple to install and has a built in GPS unit. Just another option to consider.
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
158.6 hours / Status - Flying
