sonex1374 wrote:Kerry talked about the tuning process on Episode 7 of SonexFlight, so that might be worth reviewing again for those just joining the conversation.
Once you're at WOT and the EGTs have stabilized ... slowly pull the mixture control back and listen for your RPM to increase and you watch your EGTs and you are looking for an increase in RPM coupled with an increase in about 75-100 degrees. That tells you you're a bit on the rich side for WOT and that's what you want to be.
lutorm wrote: I interpret that statement as meaning you want the full rich EGTs to be 75-100 degrees lower than what they are at peak RPM ie. best power mixture, not lower than peak EGT. ...[snip] ... But that description doesn't sound at all like what I read in the AeroCarb manual, which clearly says to lean until the engine begins running rough.
sonex1374 wrote:lutorm wrote: I interpret that statement as meaning you want the full rich EGTs to be 75-100 degrees lower than what they are at peak RPM ie. best power mixture, not lower than peak EGT. ...[snip] ... But that description doesn't sound at all like what I read in the AeroCarb manual, which clearly says to lean until the engine begins running rough.
One of the main reasons for having Kerry go over the tuning instructions was to add better clarity and understanding to the process. I'm glad his explanations in the podcast helped clear things up.
Jeff
BRS wrote:From my pic you can see that would be a higher number (which sonex calls richer?!).
