by Mike53 » Sun Sep 17, 2017 5:07 pm
dfcpac wrote:Does anyone make a cabin heat system for the Onex with the Revmaster
Engine? If so where can I get it
Thank you
Dan Carley
N127nx
The easiest solution is a heat muff over one of the exhaust pipes and then channel the air into the cabin.Here is mine.As you can see the hose goes to a box on the firewall where you can either dump the heat or direct it into the cabin.If you can't make your own muff I'm sure someone here will pipe in where you might get one or how they made there own.The gent I ordered mine from no longer does them.
Mike
http://www.onexmike.org/uploads/8/4/4/2 ... 2_orig.jpg
Mike
Antoine de Saint-Exupery
