dbdevkc wrote:I also need some references for nav/strobe lights for a Waiex, and landing light options as well. I was planning to run tubing through forward rib tooling holes and run the wiring through that. Any problems with that?
Kevin
dbdevkc wrote:I am close to finishing my other spar, and have been reviewing the discussions about up-drilling the wing mount block holes. Seems there are basically two options:
- Per the plans, up-drill to 1/4" when mating the spars, then up-drill to 3/8" when installing on the aircraft. I understand there is a tool that is being loaned around that should make that up drilling go easier.
- Up-drill the blocks to 3/8" when mating the spars, then use a 3/8" OD / 1/4" ID bushing in those holes when mounting the wing to drill the mating holes in the channel.
I'd love to hear opinions of either method and success/failure stories and recommendations.
Kevin
Users browsing this forum: Google Adsense [Bot] and 22 guests
