pschwenn wrote:Taildraggers:
What is the recommended/simplest spring setup (or other arrangement for moderating steering cable tension changes) for the tailwheel cable/steering mechanism.
[ Howcum?:
The titanium tube/spring for the tailwheel can flex quite a bit (hard landing, hard/irregular surface, poor landing, ...), changing the geometry of the steering mechanism and hence the cable tension. The standard steering rod is so simple and strong that it should not snap or permanently deform (though an alternative with, for example, "abruptly" threaded ends, could), but forces on other steering mechanism components could be high enough to wear or distort them. And setting the nominal cable tension relatively low, to accomodate, can reduce feel/control. ]
Thank you,
Peter Schwenn
he titanium tube (not a tube..a rod)/ spring for the tail wheel can flex quite a bit..." isnt what I have found. All those that I have asked about its flexability have said "no flex, just strong, brittle, and very non corosive". I have found its inability to flex very true. My titanium rod has sheared off inside the tail wheel mount (3/4..1 inch up inside) most likely due to not smoothe grass field I fly from. I have remade the rod from thick wall chromoly tube (hollow center) as also recommended by other more experienced builders (Pitts S1 for example) as they said the steel tube will indeed act much better as a spring that the titanium over short a short distance as is the TW mount to the TW swivel.
Onex107 wrote:You are absolutely correct. The thumbnail pattern shows the crack propagating for some time before it failed. There must be a surface defect at that location.
Users browsing this forum: No registered users and 43 guests
