Darick's Sonex #1646
Re: Darick's Sonex #1646
Postby Darick » Sat Sep 02, 2017 2:10 pm
In order for the "partially open position" of the canopy lock rail to be secure, I lengthened the alignment pin. The pictures below shows the lengthened pin engaged to the hole in the longeron. The pin is slightly small for this application and is not very sturdy. A bigger diameter pin may be the answer.
I didn't tap the bows, instead used lock nuts and spacers, which are the black things between the bow and canopy. Also used generous clearance holes in the canopy and bows for the #6 screws. This is the only picture I had showing that detail, while I was making airplane noises in my stocking feet.
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Darick » Sat Sep 02, 2017 2:19 pm
Finishing up a few last minute details...a cover for the master bus bar made from leftover canopy piece and Peter Anson's tailwheel steering rod.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Friesen5 » Sun Sep 03, 2017 10:50 am
Good idea using a terminal block as a buss bar. Could also be used for the grounding block.
Mervin Friesen
Sonex 122
Friesen5
Postby Darick » Tue Sep 12, 2017 8:35 am
Wings loaded up on truck for transport to airport...sob, sob, post partum wing blues
Fuselage in trailer...yes it actually fit!f
Unloading fuselage at friend's rural grass strip airport...
It took about 2 hours to put the wings on...remember to add lubrication to sliding surfaces like I did on the second one we put on. I didn't remember to lub the right wing and we had lots of problems.
Today I'll get the wing root fairings in place and riveted.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Corby202 » Tue Sep 12, 2017 6:47 pm
Great shot, picture#3 looks like you can see through the metal of the VS.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby Darick » Sun Sep 17, 2017 8:21 pm
Put wings, ailerons, flaps, pitot tube, AOA probe on this week. Tomorrow I rivet the forward bottom skin. As many have said before, make sure everything is done BEFORE you rivet that last forward bottom skin.
Remember to check all your electrical circuits too. My left wing strobe didn't work and I had to trace that down with my head behind the panel. I just realized I haven't checked the radio yet so that needs to be done tomorrow before the bottom skin.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Darick » Fri Sep 29, 2017 10:37 am
Hooray I got my airworthiness certificate 9/28!
Also started engine first time a few days ago. Had a small problem with the mixture cable attach point to carb. The little set screw at the mixture control arm, can't be too tight or it pushes the wire against the arm preventing smooth operation. Not too tight, not too loose. I'll post a picture later.
The local DAR is 94 years young and still flies a Cub! This past Saturday he flew to this private airport and not having a starter, I hand propped the old Cub...wish I would have gotten a picture of him in the Cub.
Yesterday he and two fellows from the Local FSDO, who wanted to witness the inspection, gave me the airworthiness certificate.
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Bryan Cotton » Fri Sep 29, 2017 12:37 pm
Outstanding! I better get cracking if I am going to beat you into the air.
Postby Darick » Sat Oct 21, 2017 9:41 pm
First flight today! 10/21/2017! Four years to build. Pilot friends were there! It was fantastic.
Flying off a grass field I thought it was prudent to keep the wheel pants off.
Grass was a bit long resulting in, what I thought to be a long takeoff roll. However it was good for short landing distances...below...
The cake says "congratulations Darick"
Darick Gundy
Sonex #1646
N417DG
Darick
Postby Sonex1243 » Sat Oct 21, 2017 9:52 pm
Congratulations Darick!
Ken S
SONEX #1243 N424SX (reserved)
Tail complete, wings done
Fuselage on gear
Jab 3300 received!
Sonex1243
Return to Photo Album
