by builderflyer » Wed Sep 13, 2017 7:43 pm
Check that the tach wire is connected to one of the two blue wires going between the alternator and the voltage regulator. You may need to try the other blue wire if the first is not working for you. Also, check the TachP/R setting in the EIS to make sure it is set to 6. Do you have the EIS manual?
Hope this helps,
Art,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jab 3300 #261/EIS 6000
