Running tubing thru the wing
Postby Timwaiex0146 » Wed Aug 30, 2017 3:39 pm
I have decided to install a angle of attack gauge on my Waiex panel and a probe on the wing opposite my pitot tube. Anyone have any advice or info on supporting the tubing to the probe? I want to mimic the pitot tube mount but that was installed while the wing was open. Thanks , Tim
Timwaiex0146
Re: Running tubing thru the wing
Postby Rynoth » Thu Sep 21, 2017 7:54 pm
Duplicate/fabricate the supports for the pitot/static tubing and run the AOA tubing using the same method.
Here's my blog post on the install of my LRI (Lift reserve indicator, poor-pilot's AOA.) My plan for the tubing is on the bottom half of the post.
http://www.rynoth.com/wordpress/waiex/2 ... indicator/
This post is the completion of my left wing, and includes photos of my LRI, its tubing, and also how I ran a conduit to the wingtip in case I wanted to add wingtip lighting in the future.
http://www.rynoth.com/wordpress/waiex/2 ... ompletion/
Postby Sonex1517 » Thu Sep 21, 2017 8:16 pm
Timwaiex0146 wrote:I have decided to install a angle of attack gauge on my Waiex panel and a probe on the wing opposite my pitot tube. Anyone have any advice or info on supporting the tubing to the probe? I want to mimic the pitot tube mount but that was installed while the wing was open. Thanks , Tim
I did exactly what Ryan did. Duplicated the fittings for the pitot tube hose, and made one as described here
http://www.sonexfoundation.com/Lift_Reserve_Indicator.html
While not as clear as Ryan's page, you can see some photos here
http://www.chicagoskydreams.com/Sonex_1517_Build_Log/Entries/2012/3/11_IMG_0033.html
Postby Marrahm » Thu Mar 01, 2018 12:51 am
Why run both pitot and AOA sensor? I’m planning on a single Dynon AOA probe in Pitot position and running top port to both airspeed and a mechanical AOA gauge with an adjustable zero. Dynon manual indicates that should work fine. Folks finding otherwise?
Mike
Marrahm
Postby Rynoth » Thu Mar 01, 2018 10:02 am
Marrahm wrote:Why run both pitot and AOA sensor? I’m planning on a single Dynon AOA probe in Pitot position and running top port to both airspeed and a mechanical AOA gauge with an adjustable zero. Dynon manual indicates that should work fine. Folks finding otherwise?
Mike
For me, because I followed the plans for the pitot, and decided to add the LRI probe at a later time. The pitot/static tube I had wouldn't support the LRI. Plus, I liked the redundancy of essentially 2 seperate systems for airspeed management. Since my airspeed is electronically displayed on a screen, the LRI is a mechanical backup to that.
Postby Marrahm » Thu Mar 01, 2018 6:42 pm
Makes sense. Good luck. Mike
Marrahm
Users browsing this forum: No registered users and 64 guests
