Propeller free Sonex...
Postby rbarber » Wed Jul 26, 2017 1:28 pm
All,
As many of you know already, I had my propeller fly off near Sioux Falls, SD. In hopes of saving someone some grief, the attached file is a short write up of the incident, as well as some analysis of the failure.
Regards,
R.
Robert E Barber
N157SX-Sexy Hexy
Propeller loss on a Sonex.pdf
(792.1 KiB) Downloaded 714 times
rbarber
Re: Propeller free Sonex...
Postby builderflyer » Wed Jul 26, 2017 10:07 pm
Oh no.......a new reason to worry! Very glad you got it down safely, Robert.
Art,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,Jab 3300 #261
builderflyer
Postby kevinh » Wed Jul 26, 2017 10:18 pm
Great write-up and very useful and wise.
kevinh
Postby Jim B » Thu Jul 27, 2017 7:06 am
Robert
Thanks for sharing your incident.
Jim
Jim Ballenger
snx760/jabiru2200
first flight Sept 2009
Ocala,Fl
Jim B
Postby lpaaruule » Thu Jul 27, 2017 8:00 am
Thanks for the info.
I'm not sure that there is anything actionable I should do though. My prob flange cap screws were installed with loctite 620. Replacing them at some time interval might risk twisting the heads off.
I'll have to think about this.
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Postby x3 skier » Fri Jul 28, 2017 7:16 pm
Thanks for the write up. One thing comes to be mind, which probably highly unlikely, is the use of some lower quality bolts. As an old accident investigator, that would be one thing I would require to be checked. If you can get an analysis of the bolt material, it would be well worth while.
Cheers
Onex 202, Finishing Fuselage Kit, Controls/Gear/Engine Config kit delivered.
x3 skier
Postby peter anson » Sun Jul 30, 2017 12:14 am
Hi Robert, great job getting it down safely. I've got the brains trust thinking about this problem but I suspect your idea of changing the bolts every few hundred hours is the only practical solution. The parts manual specifies plain washers under the bolts. It might be better to use a couple of Belleville spring washers to prevent the bolts from loosening. Looks like a prop removal is in my future.
peter anson
Postby kevinh » Sun Jul 30, 2017 3:00 pm
x3 skier wrote:Thanks for the write up. One thing comes to be mind, which probably highly unlikely, is the use of some lower quality bolts. As an old accident investigator, that would be one thing I would require to be checked. If you can get an analysis of the bolt material, it would be well worth while.
Yah - I'm not anywhere close to being a ME, but that is a very interesting theory.
kevinh
Return to Jabiru
