kmacht wrote:Yes. You will want to remove them. You will get all sorts of runs and dry spots while trying to spray the rear spar with the control surfaces attached. The paint will also bridge the hinges and crack when dry. At a minimum you will have to pull the ailerons to rebalance them after painting. Don't balance before you paint otherwise you will have to add lead back on to offset the paint weight.
#554
Skippydiesel wrote:Come on, surely someone made a conservative estimate, of their Senex exterior surface area, before they purchased the paint
Bryan Cotton wrote:Skippydiesel wrote:Come on, surely someone made a conservative estimate, of their Senex exterior surface area, before they purchased the paint
Perhaps not! I polished, and kept buying more until I was done.
Would be easy enough to figure out. If you do it be sure to post it for the next person!
