by 142YX » Tue Nov 20, 2012 2:14 pm
I screwed up the wing pin drilling the first time.. since then i have re-built the entire spar box and i'll be doing the wing rigging operation again pretty soon now. But the first time i aligned the wings, i didn't use them at all. I pinned the spars together through the alignment holes with three short AN4 bolts which sat underneath the overhang of the spar caps.. no spar box holes required. The aft portion of the spar box is not riveted in place when you drill the wing pin holes.. so you can easily remove the short bolts after the operation is complete and before the sparbox gets riveted together.
I dont think i am going to bother drilling these holes. this time around.
450 hours and counting..
