Dynon avionics
Re: Dynon avionics
Postby lgsievila » Wed Jun 21, 2017 2:32 am
You are correct Chris and in the IEC standard "J" type positive is black and "K" type positive is green. My point was it can be confusing where in my Dynon Red T/C's go to a certain pin number and yellows to other pin numbers and Dynon takes care of the polarity.
Loren Sievila
Conventional Gear Onex33
CAMit 2200
Dynon Skyview
lgsievila
Re: Dynon avionics
Postby SonexN76ET » Wed Jun 21, 2017 9:45 am
Loren,
Your panel looks great! How do you like the CAMiT and the Prince Prop?
Jake
Sarasota, Florida
SonexN76ET
Re: Dynon avionics
Postby lgsievila » Wed Jun 21, 2017 1:17 pm
Hi Jake,
Working great and getting honest 1000 fpm climb with a cruise prop and I weigh 230 . Had to put in a little larger needle jet for cruise rpms to get the EGTs down a little. Just sips gas and no other problems.
Loren Sievila
CAMit 2200
Dynon Skyview
lgsievila
Re: Dynon avionics
Postby surfly » Wed Jun 21, 2017 7:31 pm
Doug, this "older guy" will be 70 in September. I appreciated your input especially when I read your location. I am building my Onex in a hangar at Valkaria airport (X-59). sfc3bc@gmail.com.
Also, Loren thanks for the photo's of your panel. The 7" SkyView fits well in your panel. Beautiful job. Sherm
surfly
Return to Onex
Users browsing this forum: Google Adsense [Bot] and 8 guests
