by N814W » Thu Jun 08, 2017 12:06 pm
Folks,
Obviously, I've finally pulled the trigger on my fuselage kit and am continuing with my OneX build. Part of my delay has been analysis paralysis, part of it has been expectations management, and part of it has been "life". It's the right time in life again, I think I have my expectations properly tempered, but there's still a lot of unknown questions I have on "nice to haves" vs. "worth the effort". Hoping a few folks who have been there & done that can weigh in with food for thought.
Let's start with landing gear: I'm based on a 2100 ft. turf field. I think I've picked up that the factory wheels & tires are especially small, and there seems to be a number of folks who have had their factory wheel pants involuntarily removed on turf fields. My desire would be to go to 500-5 tires and Vans RV wheel pants. I think I've seen where a couple others may have done this. Is this documented or laid out somewhere I could read up on more?
Brakes: consensus seems to be that the factory hydraulic brakes are sufficient, but I'm guessing that won't plug & play with someone else's wheels to correspond with the 500-5 tires. Thinking about using a system from Black Max brakes. Anyone else use these that can comment these systems? Thoughts on locating the brake lever on the stick vs. the fuselage side? I plan to build a taildragger and would like to be able to hold brake pressure, control the stick, and run up the throttle for run-ups, so a stick mounted lever seems to be a good solution, but I'm open to other thoughts.
Order of assembly - for the sake of systems installation, does it really matter if I go for wings next vs. finishing kit next? Obviously, it would be a lot more convenient if it was sitting on the landing gear when working on the center wing section. Is there enough work to actually "do" on the finishing kit so I can stay "busy" while I squirrel away wing kit fun money? Also, seems like everyone has to do some clearance operations for the elevator push rod and rudder cables. Should I leave the turtle deck in clecos until all the controls installed, or just deal with the tight space as and when the time comes. I don't have huge hands, for whatever that's worth.
Engines: yeah, yeah...Pandora's box. My thoughts are either (1) Hummel 85 hp. Right price, better alternator, actual magnetos, and a real carburetor. Seems perfect. Or (2), either of the UL Power 4 banger engines are hugely tempting for all the obvious reasons, except for price and the dependency on electrical power for fuel & ignition systems. My primary requirement is to be able to run on pump gas vs. 100LL. Not sure what Hummel's engine needs for octane or ethanol compatibility. Both UL engines will run on 91 ethanol pump gas which is about the same price as the ethanol-free 87 I run in my Cessna and have been accustomed to budgeting for. My building buddies are building O-360 powered RVs, which they will no doubt leave me in the dust just because they can on a regular basis...so the bigger UL engine is definitely tempting. But, I suspect that their first flights will be 2-3 years after mine, so I can probably stomach being the last person to arrive just fine. After all, you can only log hours, not miles... :)
Avionics/instruments: I've analyzed this ad-naseum and realize this is a hugely personal decision...my only real question is, is there really a combo of quality round dials for VFR that can end up cheaper than a GRT mini or MGL mini that includes altitude, airspeed, compass, G-meter, VSI, and legit engine monitoring? If so, I'd love to hear your thoughts.
I'm sure more will come up along the way. So far, I'm having a ball with the fuselage & thanks all for your advice & input!
Cheers,
Brian
N814W on Thu Jun 08, 2017 2:05 pm, edited 1 time in total.
C150 driver by day, OneX 204 builder by night.
Empennage done, fuselage in work...
