Splice plate fitment question
Postby N814W » Wed Jun 07, 2017 2:18 pm
Do the F21-07 splice plates need radiused to nest into the vertical cross tie channels? This doesn't look right...
C150 driver by day, OneX 204 builder by night.
Empennage done, fuselage in work...
N814W
Re: Splice plate fitment question
Postby peter anson » Wed Jun 07, 2017 10:54 pm
I don't recall having to do it on my Sonex but if it won't fit flat against the angle without a radius, that's what you have to do. A bevel would also be OK.
peter anson
Postby N814W » Thu Jun 08, 2017 10:35 pm
There, I fixed it.
But leads to the next question - should the little spacers be tapered? The aft edge of the lower cross tie skin is about a skin's thickness proud of the lower longerons.
N814W
Postby Don_P » Sat Jun 10, 2017 8:24 am
Regarding splice plates, here's a very minor item you might want to look at: A couple of years ago, while working on the forward/aft fuselage splices, I found that the Aft Fuselage Floor Spacer (ONX-F21-10) was too thick. Unless Sonex has modified this part, it is still 1/8" thick. If you do the math, however, you'll find that the spacer should be 1/8" minus the thickness of the bottom flange of the Lower Cross Tie #1 (ONX-F19-05), which works out to 0.093" (or about 3/32"). If the thicker spacer is used, the Lower Horizontal Splice Plates (ONX-F21-06 R/L) will be rotated slightly along their longitudinal axes. I remade the parts, but you might want to check yours to see how thick it is. Getting it right will improve the fit.
Don
Onex 0095
N464D (reserved)
Don_P
Postby N814W » Sun Jun 11, 2017 12:46 pm
Don_P wrote:Regarding splice plates, here's a very minor item you might want to look at: A couple of years ago, while working on the forward/aft fuselage splices, I found that the Aft Fuselage Floor Spacer (ONX-F21-10) was too thick. Unless Sonex has modified this part, it is still 1/8" thick. If you do the math, however, you'll find that the spacer should be 1/8" minus the thickness of the bottom flange of the Lower Cross Tie #1 (ONX-F19-05), which works out to 0.093" (or about 3/32").
Still 0.125". Took a bunch of filing and sore thumbs, but I got them thinned down and the cross-tie figment looks good.
N814W
Return to Onex
Users browsing this forum: No registered users and 25 guests
