WaiexN143NM wrote:Hi all,
Yes good to have pushrod with ball ends to pivot, because as the tailwheel rod spring flexes the angle changes. The factory supplied pushrod is a fixed rod, so no allowance for flex. Good to keep a good eye on all components of the tail wheel assembly. Remember the late great ken brock, who when landing his thorp T-18 at paso robles ca. Had the whole tail wheel bracket come off, lost directional control, went off runway , filpped over and broke his neck. The main pivot bolt had been ground down from repeated landings and flex, and finally failed.
My waiex is down in tucson, can a few of you take some measurements for neutral length between the pivot holes? Will pass on to blake at flyboyaccessories . They have a neat spring loaded pushrod for the rv vans aircraft, but that is a little long for us. I talked to him last year osh16 about this, told him id get back to him with a length , so he can have their vendor make some up for us sonex drivers. I think with ball ends and a spring loaded pushrod would be ideal.
Please post the length here and i'll pass on to blake.
WaiexN143NM
