Looking for advise on Sonex with 2180 Revmaster
Postby Planegene » Thu May 18, 2017 9:49 pm
Been talking to someone about a possible purchase of a Sonex with a Revmaster 2180.
What kind of performance will I be looking at?
I have never had a Revmaster, is it a good fit?
What should I look for when I go to look at the plane?
Any advise is great
Planegene
Re: Looking for advise on Sonex with 2180 Revmaster
Postby gammaxy » Thu May 18, 2017 10:39 pm
A lot also depends on the propeller. I don't know much about the Revmaster, but expect that it will perform about the same as the Aerovee which has the same displacement.
I'd expect climb rates around 800fpm with a 200 lb pilot and around 450fpm at gross weight at 75mph. If your propeller spins faster than ~2850rpm at that speed you'll probably climb a bit faster.
True airspeed at wide open throttle will probably be in the range of 125-145mph depending on the propeller.
Chris Madsen
Aerovee Sonex N256CM
Flying since September 2014
gammaxy
Postby Planegene » Sat May 20, 2017 5:54 pm
Is there anything I should look at other than the obvious as far as airframe?
Any major service bulletins?
Weak spots
Planegene
Postby gammaxy » Sat May 20, 2017 9:49 pm
Here's some pre-purchase guidelines on the Sonex Foundation website:
http://www.sonexfoundation.com/uploads/Pre_Purchase_Inspection_v2.pdf
Sonex keeps a list of service bulletins here:
http://www.sonexaircraft.com/support/se ... etins.html
Chris Madsen
gammaxy
Return to Sonex
Users browsing this forum: No registered users and 57 guests
