MichaelFarley56 wrote:Those are the ones Noel! You got it right. Just twist them in as far as they'll go; they should bottom out into the threaded insert locations in the heads.
Your engine looks fantastic!
Thanks, Michael and Bryan!
The studs never bottomed-out, though. The threads had a bit of interference to them when screwing them in, so I double-nutted them and used that to gently twist them into place until they reached the depth you see in the photos.
BTW, Bryan (and others) - For trimming the head studs, which some people really find a PITA to do on the engine itself (not to mention the metal filings it throws all over your engine), here's what I did:
I torqued the nuts to 10 ft-lbs, then gently double-nutted one of the studs that needed to be trimmed. I used the double-nut arrangement to unscrew that one stud from the engine block, took it over to the other side of my workshop, and trimmed off the excess with a Dremel. Then I wiped it down with a bit of alcohol/solvent (to clean off any metal dust), undid the double-nut arrangement, and reinstalled the stud onto the engine. I put the washer & nut back on, seating it down finger-tight. After doing this for all 3 studs on each head, I used the torque pattern shown in the assembly manual to re-torque all of the nuts to 10 ft-lbs. Worked like a charm! The only grumble-worthy moments were with the studs what retain one end of each super-tin. The friction from the tin meant that I couldn't simply thread the stud into the block by hand. So I used one hand to pull the corner of the super-tin down (to free up the stud) while I worked it into the block with the other hand.
I'm now using the same procedure for the head studs that interfere with the rocker arms. Tedious, but after building the airframe I'm no stranger to assembling something, then taking it apart once or twice! :-)
Thanks again,
--Noel
