Mike53 wrote:Here it is- http://aircrashed.com/cause/cERA09CA162.shtml
Andy Walker wrote:Here's another potential alternative engine for the Sonex/Waiex/Xenos, the UL Power UL260iSA:
http://www.ulpower.com/engines/ul260iSA/index.html
It's a real aircraft engine with dual ignition, air cooling, and a horizontally opposed design with oil pickup designed with ability to fly inverted. 107hp continuous at 3300rpm at a weight of 160-165lb puts it right in the Jabiru 3300 ballpark. Here are some of the factory features of the UL Power engines:
Modern Technology 4 stroke, air cooled, 4 cylinder opposed engine
Dual (redundant) electronic spark ignition (variable timing)
Multipoint electronic fuel injection with automatic altitude and temperature compensation
Electronic RPM limiter
Direct propeller drive
Wet sump forced lubrication with integrated pressure regulator
5 bearing crankshaft with thrust ball bearing
Ram air cooled cylinders and cylinder heads
High fuel efficiency
No carburettor icing problems
Excellent power to weight ratio
Electric fuel pump and pressure regulator to eliminate vapor lock and facilitate starting even under adverse conditions
I have not looked at the dimensions relative to the existing Sonex/Waiex/Xenos engines, so I'm not sure how well the current cowls might work. But this looks like a contender on paper. The only downside is at current exchange rates the price comes to about $23,600, which makes it a LOT more expensive than a Jab 3300.
kmacht wrote:So if it is about the same price as a 3300 whats the advantage? Isn't the 3300 120hp vs 97hp for the UL? What am I missing?
