Rod End's
Rod End's
Postby Corby202 » Wed May 10, 2017 2:53 am
What maintenance do you guy's do to the rod end bearings on the controls??
Phil
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Re: Rod End's
Postby 9GT » Wed May 10, 2017 8:59 am
LPS-2 would be a good choice.
David Clifford
Howell & Gladwin, MI
RV-9A: Under Construction (I'm a repeat offender!)
RV-10: Built & Sold: Flying Since 2013 N959RV
Cozy MKIV: Built & Sold: Flying Since 2007 N656TE
9GT
Re: Rod End's
Postby mike.smith » Wed May 10, 2017 7:11 pm
Q: What maintenance do I need to perform on my rod ends and spherical bearings to keep them operating properly?
A: For metal-to-metal rod ends and spherical bearings, a thin layer of grease applied occasionally to ball outside diameter will assist in extending the life of these products. Rod ends and spherical bearings that are Teflon lined are self-lubricating and are designed to be maintenance free and should not be lubricated.
Source: http://www.aurorabearing.com/technical-faqs.html
Personally I stay away from grease simply because it picks up dirt and grime very readily. I like things like LPS-2 or Wurth HHS-K. Note that LPS-2 is indicated by the manufacturer for "indoor" use.
Re: Rod End's
Postby Corby202 » Thu May 11, 2017 1:50 am
Thanks. I had been told that rod ends should be repacked with grease occasionally but that seemed like an over kill.
Phil Bird
Corby202
Re: Rod End's
Postby rizzz » Thu May 11, 2017 2:05 am
Corby202 wrote:Thanks. I had been told that rod ends should be repacked with grease occasionally but that seemed like an over kill.
Hi Phil,
Yeah that might be overkill, LPS-2 is sufficient in my view.
Maybe after some years you can consider doing this:
http://www.eaavideo.org/video.aspx?v=1628410977001
But it means of course disassembling everything...
