cutting hole in wind screen
Postby dfcpac » Tue Apr 25, 2017 6:23 pm
does any one know what size hole I have to cut for the fuel cap in the wind screen. what is the best way of doing this
thanks
dan carley
n127nx
dfcpac
Re: cutting hole in wind screen
Postby onex28 » Tue Apr 25, 2017 7:06 pm
Check your plans for size and location, I believe it is about 4.5". Find some on who knows how to use a fly cutter and make sure the cutting tool is turned the proper way. You want the bevel on the scrap piece, not the windscreen.
David
onex28
Postby wlarson861 » Tue Apr 25, 2017 11:43 pm
I installed snap vents in the sides or my windshield and found a hole saw works well. I used the hole saw while the windshield was mounted and had no problem. A fly cutter must be used in a drill press with the Lexan firmly clamped. A hole saw in the drill press is ideal, the downside is buying one for just one hole.
Bill Larson
N861SX
wlarson861
Postby WaiexN143NM » Wed Apr 26, 2017 12:36 am
Hi all,
Yep just like bill said a hole saw works well, winscreen mounted on fuse, a shop vac is good to catch all the mess. Dont be timid, that lexan is tough.
Users browsing this forum: Google Adsense [Bot] and 13 guests
