Greetings...
- 3300A s.n. 1053, upgraded lifters and pushrods
As part of my pre-flight, I hand prop the engine through all cylinders. Yesterday, I heard a 'clanking' noise, so I went around again. I heard the same noise at the same location, so I investigated further. Seems it's just before TDC on cylinder 6, and can be reproduced just by rocking the prop back and forth.
https://drive.google.com/open?id=1AKVFA ... 4xKfw9eWBAAs seen in the linked video (can't seem to attach it) , the noise only occurs when there is compression, disappearing when spark plug hole is open. It's quite a loud 'clank', and takes very little prop movement to repeat ad infinitum. Note that both valves are closed and there is no discernable movement of either rocker, which would seemingly eliminate the valve train a suspect.
Any ideas?
