by Sonex1517 » Fri Apr 05, 2019 11:22 pm
This thread is almost four years old now, but I wanted to post an update since I started it.
I ended up with a GRT Mini EFIS, a GRT SafeFly 2020 complaint GPS, and a uAvionix Echo ADS-B in and out solution. I removed the Stratux, but really did like the cost and simplicity.
While I’m not thrilled with the documentation and amount of configuration involved, I am thoroughly impressed (again) with GRT tech support. Clint Rosendall, Production Manager at GRT, was helping me and even replied on the weekend when some of their staff was at SunNFun.
While the challenges I had were self-induced (one incorrect wire, several incorrect menu settings) in the end I got it working. I have not flown the flight test with the FAA yet, but am hoping to soon.
The solution cost about $1500 (less due to buying it at Oshkosh 2018), and was straightforward to get working once I got past the configuration settings. I will post final results once I know my ADS-B out passes the FAA flight check.
Just passing this along for others considering adding ADS-B out before the mandate. There are certainly several good, affordable solutions available. This is just one of them.
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
