by dbdevkc » Mon Oct 01, 2012 1:41 pm
Per the Sonex instructions:
"As a last general step, remove any stress risers that may remain including
scrapes, scratches, or the slight edge from the leg of the angle that was
removed. This can be done with a dual action or palm sander or with the Scotch
Brite pad or wheel."
Does "...the slight edge from the leg of the angle that was removed." mean
remove the entire 'slight edge', or just smooth it out? Seems like quite a bit
of material and would take quite a bit of work on the scotch brite wheel.
Kevin
[color=#800000]Kevin Conklin
Building Waiex #169
