N190YX wrote:Guys, if your airplane is not 100%, please don't fly it! The notion of flying an engine that is not 100% to see if the issue will correct itself is a recipe for a disaster! ... TCM Continental allows no leakage past an exhaust valve, if leakage is detected in a compression test, the engine is not airworthy, the cause must be corrected. I repeat, please do not fly if your entire airplane is not 100% operational. We have got to keep our safety record as good as we can!
rizzz wrote:Went for a flight the other day and before going out I manually rotated the prop.
I noticed considerably less compression on 2 (#4 and #3 I believe) of the cylinders, also, I can hear a hissing in the exhausts during compression.
Leaky exhaust valves? Certainly showing all the symptoms…
mike.smith wrote:rizzz wrote:Went for a flight the other day and before going out I manually rotated the prop.
You don't have the Nickasil cylinders, do you? If you say yes then I'll tell you what may be up. If you say no then disregard :-)
