If you still have everything set up you could run through this experiment for more knowledge. On the face of the hub put a sharpie mark when the dial gets to 0 (the lowest reading). Then rotate to the 0.013" (Highest reading) and put a sharpie mark. Then do both of the 0.0065" readings with sharpie marks. If all sharpie marks are 90 degrees apart, then you know the hub is not bent and the face is fairly flat.
DCASonex wrote:Got one of Sonex new hollowed out lighter weight prop hubs a while back .......
David A. Sonex TD, CAMit 3300
SNX1508 wrote:DCASonex wrote:Yes, I have probably not given the proper attention to aircraft weight during the build and now want to trim off a few pounds !!
Any feedback greatly appreciated.
