samiam wrote:Thanks Bryan. I guess I just need to acknowledge that I am an amateur builder, and as such there is the chance that there could be a 1cm twist and that I just would have to live with it
Eh, I found I worried a lot about twist until I was actually building the wing. Once I had it set firmly on blocks to keep it level on my table, things went pretty easily. I checked a few times throughout the process to ensure the root & tip of the wing were staying level, relative to each other - it was no sweat!
I did my first wing totally horizontal. I decided to try the other wing in the vertical position,
squaring the spars and shimming the main spar at the tip to get them to be oriented the same (see
lower right part of this photo). Once I had the
first skin cleco'ed in place, I decided I liked working in the horizontal orientation better. Pushing against the wing skins could rock the whole assembly if I wasn't careful, and I didn't want any bumps to screw up the alignment. So I rotated it horizontal and
blocked & shimmed it up to be level at root and tip.
Overall, I found the horizontal orientation easier to be precise with and keep consistent (gravity is helping, afterall, and you can use small
wood blocks on either side of the main spar screwed into your table to hold the wing in-place). The vertical orientation is easier for squaring the spars and getting started; but I found that a wire-based plumb-bob in the tooling hole (as some builders and websites show) can be inaccurate based on friction and slight bends in the wire or how perpendicularly it sticks out of the tooling hole. Plus, very small shims under the spar can make a big impact on the twist. As a result, its a little trickier to get the wing twist-free in the vertical orientation IMHO. With the pre-drilled holes that come with the more-recent kits, the rib/spar squaring process should be a whole lot easier in either process (...yes, I'm jealous)!
Start with a flat table. Use a big/long level. If your level can't span the gap between main & rear spar, use a piece of angle aluminum or other strong material that won't flex and place your level on top of that. Get the readings the same at root & tip and you're ready to rock'n'roll! Lock things in position if you can, with wood blocks or straps or whatever works for you. Re-check your measurements every so-often. Try to have fun!
Enjoy,
--Noel
Sonex #1339
