Curved glare shield and instrument panel
Postby lstinthot » Sun Mar 12, 2017 10:09 pm
Does anyone have the dimensions to make the curved glare shield and instrument panel? I have experimented a bit today coming up with a smooth glare shield. Only one more piece of 0.032" big enough to make it over again. Today's piece started out big then I cut some off the firewall end and took too much off. I am pretty close to getting it, just curious if anyone else that has done this has the dimensions they ended up at.
Mike
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
Re: Curved glare shield and instrument panel
Postby GordonTurner » Mon Mar 13, 2017 3:50 am
Mike
I was planning to make the same kind of modification. You're way ahead of me so I can't help you, but, looking forward to seeing what you come up with. One thing I have read from somebody that did this mod previously is they left the hex glare shield in place, with a bunch of lightening holes, as it is containment for the fuel cell.
Gordon
GordonTurner
Postby Ercoupechris » Mon Mar 13, 2017 2:35 pm
Ben McGuinness has the curved glare shield. I thought of contacting him about hows he did it but decided to go with the "B" model conversion. I believe Ben's contact info is in the builders database on the Sonex website. Here is a link to some photos.
https://sonexaus.wikispaces.com/Ben+McG ... +Waiex+104
Chris Schuldt
703-928-5199
BRM Aero Bristell NG-5
"B" model Conversion Waiex s/n 64 4th owner, kit from 2007
Edge Performance 915-ECi 120 HP EFI with Ring Mount
Rotax iRMT Service
Rotax iRMT Maintenance
Rotax iRMT Heavy Maintenance
Ercoupechris
Return to Sonex Plans
Users browsing this forum: No registered users and 34 guests
