by Ercoupechris » Thu Mar 02, 2017 9:41 pm
Unfortunately, Stall /spin accidents are the single largest cause of fatalities in general aviation... PERIOD!!!.. No one can know nor can the NTSB know for sure in the end, BUT, the fact is that the "Human Factor" is the least understood and most dangerous thing we face as pilots. When everything is going to hell in the cockpit, it takes us 5 times as long to react and our ability to maintain clear thought and do all of the right things to safely get to the ground is exponentially more difficult. This is why if you evaluate NTSB accident reports, even when engine failures occur, they always cite that the pilot failed to maintain controlled flight to the ground (paraphrasing). As we all know, airplanes don't fall out of the sky nor do they hit immovable objects without guidance from the pilot. The best way to force yourself to learn these things is to practice slow flight and if possible, practice engine outs as much as you can and understand what the airplane is telling you. Experience and training (to include self training/practice) will aid you in using rote memory to overcome things in a more automatic fashion.
If you evaluate stall/spin accidents, to include hitting immovable objects, you will generally find that better options for where to put the plane down were available and but for the "Human factor" and our inability to process the situation with little if any time to spare, most are survivable. In the end, we have to NEVER stop flying the airplane since as long as it is flying, we have some control overt the situation. Trying to push the aircraft beyond Bernoulli's principle (available LIFT) in hopes of making it one foot further forward than the airplane can fly, only hastens the speed at which we hit the ground or immovable objects.
Personally I'd rather land on a moving car or in tree tops or anywhere else that won't create a sudden stop. Touching down at less angle and at or just above stall speed is the name of the game. We have to become the best energy managers that we can be and know that no matter what, the Human Factor and lack of experience will more than likely make us a statistic for which we cannot survive.
And for the record, I have survived one complete engine out that resulted in an off airport landing and a partial engine out that was nursed to the next airport. I am sure that other here can reflect on similar incidents. Had I been a low time pilot during either of my incidents, I likely would not have fared so well.
This is an important discussion that we should never be afraid to have, here, or anywhere else. I hope this doesn't offend anyone but if so, so be it
Chris Schuldt
703-928-5199
BRM Aero Bristell NG-5
"B" model Conversion Waiex s/n 64 4th owner, kit from 2007
Edge Performance 915-ECi 120 HP EFI with Ring Mount
Rotax iRMT Service
Rotax iRMT Maintenance
Rotax iRMT Heavy Maintenance
