petep wrote:I want to remove the nice red cover plate on the lower front left where Sonex machined open the oil pan so that I can install the oil temp sensor there vice in the oil drain plate. Does anyone know where I can find a new gasket for this plate?
kmacht wrote:Go to any auto store and ask for an oil change gasket kit for a 1970 vw beetle. Most of the places will stock it. You will be removing that cover at every oil change to clean the screen in there so buy a few. The kit will come with 2 paper gasket. One goes under the screen and one goes on top of it. The kit will also come with new copper washers for the nuts holding the plate on as well as the drain plug. The kit should be between 5 and 10 dollars
#554
Users browsing this forum: No registered users and 86 guests
