WaiexN143NM wrote:Hi all,
Now one into a condo roof in mass.
rizzz wrote:Even though I 100% agree with the statement that your best chances of survival are to fly the plane as long as you can into the crash, I totally disagree with the "you can survive pretty much anything at 40 mph" statement.
This might be almost always the case in a car, a Sonex is not at all built like a car, it does not have wrinkle zones, airbags etc.
If only your body were to impact the ground or anything else at 40 mph, it is a toss of a coin whether you'd survive or not, it would be about the same as an average size adult falling from a 2 to 3 story building, survivable, maybe, but only with a lot of luck.
In a Sonex you'd be a little more protected at the moment of impact but nothing like in a car, the G forces your body will experience in a Sonex crash will still be much greater than in a car crash at the same speed, purely because of the fact that the wrinkle zones of the car will absorb most of the G forces.
And lets put impact forces aside for a second,
Often the actual cause of death will not be excessive G forces your body experiences but rather severe head & spinal trauma, puncturing of vital organs etc from hitting things in the cockpit that your body is thrown towards and/or are thrown at your body.
Cars have many safety features we just cannot include into our airplane because of the weight concerns, for example, cars have mechanisms to pull the steering wheel away from you on impact.
Just imagine what will happen with that whole glareshield/fuel tank/instrument panel structure if you hit a wall nose first at 40 mph, it will come straight at you and in the meantime your head is moving straight towards it. If you do manage to miss it the recoil will then throw your head back again and guess what, there is no headrest to stop it like in a car which means your neck will be subjected to a severe whiplash event.
Anyway, I might have gone a bit too much into the horrible details but I just thought the statement made was a bit of a dangerous one and needed correction as it implied a sense of indestructibility as long as you stick to the don't exceed 40 mph rule...
samiam wrote:2. Your point about the G loads is not exactly true. The analogy of jumping from a height of 2 or 3 stories is not really applicable to a 40mph accident, it's analogous to a stall/spin accident, which is why it's so fatal. The difference is that when you impact the ground, your deceleration distance is essentially zero so the G loads are very high. Rod Machado once did a piece on this, where he shows that the math behind it. As long as an airplane crashes at 50mph and slows over a distance of 10 feet or more, the G loads will not be fatal. This is why someone can crash into a building through a window and survive, but if they hit a brick wall they will not.
