Rivet squeezer for wing spar
Postby surfly » Sun Feb 26, 2017 7:59 am
Good morning,
Please share with me methods used in setting the rivets into the Onex wing spar. I haven't been able to find rivet squeezer jaws wide enough to do the job.
Surfly
Onex 0176
surfly
Re: Rivet squeezer for wing spar
Postby Mike53 » Sun Feb 26, 2017 1:35 pm
I used a c-frame which worked beautifully .Just make sure you do it on a solid surface with no bounce or give .
The c-frame can then be used for dimpling the forward skins which is a bonus. http://www.onexmike.org/spar--inboard.html
Mike
Mike
Antoine de Saint-Exupery
Mike53
Postby dhogue » Sun Feb 26, 2017 6:27 pm
I know you are inquiring about a rivet squeezer but I'll pipe in anyway.
I used a 4x rivet gun and a very dense tungsten bucking bar and did it by myself. I had to replace 7 of the longest rivets with bolts as I elongated those 7 holes when extracting them as they were unacceptable.
Don Hogue
Onex 0173: Tailwheel: AeroVee Turbo.
Horiz/Vert Stabs, Rudder/Elevators, Fwd/IB/OB/Aileron Bellcranks on Ribs and Main Fwd/Aft Center Wing Spars, Fuselage : Complete.
WIP: Wings
dhogue
Postby wlarson861 » Mon Feb 27, 2017 1:07 am
A pneumatic squeezer big enough to handle a sonex spar is a bench mount type. I have seen one at Sonex's warehouse set up on a bench that I assume they use to rivet the spars that they sell pre-built. Ats has several but as you can see they are very expensive.
https://www.aircraft-tool.com/shop/sear ... +SQUEEZERS
Bill Larson
N861SX
wlarson861
Postby gcm52 » Mon Feb 27, 2017 12:29 pm
I have a big Chicago pneumatic 351 rivet squeezer that I used to set rivets on my Zenith 701 wing spar, but it did not work for the Onex. I ended up setting the rivets with a rivet gun. I too screwed up about four rivets and put in bolts for those four. Sonex also has a method for setting the rivets with a hammer and a bolt, you could look into that as well.
George Mueller
Onex Trigear
Rotax 912 ULS
gcm52
Postby Bruce593SX » Mon Feb 27, 2017 2:58 pm
I did the hammer/bolt method, was surprisingly easy, just get the sonex bucking bar and do it on the concrete floor
Bruce Johnson
Sonex 593 AeroVee Turbo
Plans building near San Antonio, TX
Bruce593SX
Postby markschaible » Tue Feb 28, 2017 11:13 am
Hello SonexBuilders.net,
Checkout our video on solid riveting with the bolt & hammer technique (our recommended technique for our spars), and see a bunch more helpful video tips at: http://www.sonexaircraft.com/support/vi ... l#drilling
markschaible
Return to Onex
