Andy Walker wrote:I guess I'd better lose 6lb. :(
fastj22 wrote:Andy Walker wrote:I guess I'd better lose 6lb. :(
Or buy the Aerovoltz Li-Iron battery. Saves you about 12 lbs.
structurespilot wrote:184 lbs + approximately 12 lbs for an engine mount (taildragger)= 196 lbs FWF without battery, or Propeller. What about the 200 lbs FWF limit? Does the TRI gear mount weigh more? Anyone know?
Regards, Norm
Mike53 wrote:structurespilot wrote:184 lbs + approximately 12 lbs for an engine mount (taildragger)= 196 lbs FWF without battery, or Propeller. What about the 200 lbs FWF limit? Does the TRI gear mount weigh more? Anyone know?
Regards, Norm
I weighed the tri gear engine mount for my Onex assuming the Aerovee engine and it weighed just under 5 lbs. Quite the difference from a Jab mount.
fastj22 wrote:Mike53 wrote:structurespilot wrote:184 lbs + approximately 12 lbs for an engine mount (taildragger)= 196 lbs FWF without battery, or Propeller. What about the 200 lbs FWF limit? Does the TRI gear mount weigh more? Anyone know?
Regards, Norm
That just doesn't seem right. It should be maybe a pound difference. One of you are not calibrated correctly.
