Sonerai13 wrote:You're not going to have room for the slobber pot (aka the "oil separator") up that high on the firewall. You'll probably have better luck mounting it on the engine mount tubes using Adel clamps. Other than that, it will probably work. Just make sure you can get the battery in and out easily, and can get at the connections without too much trouble.
NWade wrote:Thanks, Joe - I trust your knowledge and opinions here more than just about anyone!
NWade wrote:...But... :? I lined it up on the firewall and it seems like it'll fit OK. What am I missing?
Sonerai13 wrote:Thanks for the kind words. Remember that my opinions are worth exactly what you pay for them!! :)
As Josh mentioned, you have to remember that you can't get at the backside of the firewall up that high once the tank is installed (without removing the tank), so you need to be careful about what you put up there and how you mount it.
I'd echo the opinion not to drill any holes in the firewall until you have the engine hung on the mount with all accessories installed. That doesn't mean that you have to leave the engine on permanently, but you should hang it on there and make sure everything fits and that all your hoses and wires will route in a sensible manner. It wouldn't hurt to hang the engine and fit the cowl before making any final decisions. Don't get too far ahead of yourself.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 30 guests
