Fuel Tank flow Test
Fuel Tank flow Test
Postby Sonex 772 » Thu Feb 16, 2017 7:48 pm
Hey All
Many years ago there was a formula on here on how to check the fuel flow rate coming from the tank. It was by putting in 1 gallon of fuel in the tank and then timing how fast it drained out and doing a calculation on what the flow rate would be, dose any one know what this formula is??
Thanks
Mike
Sonex 772
Re: Fuel Tank flow Test
Postby Bryan Cotton » Thu Feb 16, 2017 8:43 pm
Mike,
If you time the gallon drain time in seconds, divide seconds by 3600 to get gallons per hour.
Postby lpaaruule » Thu Feb 16, 2017 8:56 pm
I'm reluctant to do math where the world can see, but here goes....
If 1 gallon flowed out in 3 minutes and 22 seconds then I would calculate it this way:
3 min + 22 sec = 3 min + (22sec/60sec) = 3 min + 0.366 min = 3.366min
Then convert 3.366 min to hours by: 3.366min/60min = 0.0561hr
So if you want gallons per hour, since you only flowed 1 gallon, it would be 1 gallon / 0.0561 hr = 17.8 Gallons/Hour
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Postby onex28 » Fri Feb 17, 2017 12:36 am
Or, divide 3600 seconds ( 1 hour ) by 202 seconds ( the time to drain your 1 gallon ) and you arrive at
17.82 gallons per hour.
onex28
Return to Sonex
